Happy Birthday RAYJAY
By Kingfish
By mac66
By sxr951
By TimsBrickHouse
DO NOT BUY ANY THING FROM HISUN Period! I had the axis 700 for 2 months when a rat or squirrel ate both wiring harnesses. (Main & ECM)Wanna know why? Because the manufacture of these things in their infinite wisdom use either, a soybean oil or a peanut oil to run the wires through the the wire loom. Hmmm i wonder why they would be inclined to eat the wires. So now I have $10K machine that I've only had for 2 months when all this happened and they will not warranty it at all. It is going to cost me $800 to $1000 to get this fixed. Here is a link to a video showing where we took our Hisun notice how many are there:
https://photos.app.goo.gl/2FdniAoCyvTJMKae7
So counting mine, there are 16 of Hisun Axis on the lot that i took in for authorized dealer, with the exact same problem, plus other troubles that the mechanic explained to me. This particular place told me they are not going to work on them anymore. I will be posting this in as many places as possible to reach the masses. I hope its worth Hisun!
