  • Alex changed the title to Land Pride Treker 4410 clunking and jerking
Hard to say whats exactly wrong, we have a Hisun 700 and the rear differential/gear box destroyed the pinion bearings to that the pinion would be too sloppy to engage the ring gear and had similar effects. It would clunk and not move and then jerk forward randomly until finally it just about gave up moving at all, except a bit in reverse. Swapped out the differential for an aftermarket yamaha one solved the problem.
      Greetings All,
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Graffy
