T-boss 410, I have no idea. The service manual said 1400 kPa. 1400 kPa/6.895 kPa/psi = 203 psi (not 217, my bad). I'm already operating way above my pay grade on this. I have gone above and beyond to fix it, but now I'm ready to move on, cut my losses, pick myself up, dust off, and load the SOB on a trailer.
k-bo
Current status: On 3/7, I put everything on the vehicle back together and took it to San Marcos Powersports, a Massimo dealer. As anticipated, they are backed up with repairs for weeks and are having labor issues just like most small businesses these days.
Prior to packing it up, I did a proper compression test and got 105 psi. So, this still seems low. Here's the summary of it all now: cranks and will not start, has initial one time fire at beginning, throws P0201 (injector malfunction) and P0351 (ignition coil issue) codes, has spark and fuel, ignition coil and pickup coil have good resistance readings as does the stator, no visible mechanical issue - everything engages and turns, and wire harness is delivering voltage to ignition related circuits. ECU function and electromechanical ignition triggering cannot be verified with my current toolset. So, I have punted.
k-bo
  • 4 weeks later...
Just for fun if your compression is as low as you say check the valve adjustments a tight valve could cause the loss of compression and also cause it not to start.
  • 5 weeks later...
Update on my T-Boss 410: It has been a San Marcos Powersports for over a month. They started evaluating it about 2 weeks ago. The mechanic there determined that it has a broken crankshaft chain. This explains the low compression readings and the computer confusion. Parts are now on order and an end to this saga is in sight. It'll cost me less than I thought, but it is still quite a chunk of change nonetheless.
More to come...
k-bo
    • By Joe Breaux
    • By SteveS
    • By D MAYNARD
                                    Thank You,
                                  D Maynard
    • By downseast
      Hi everyone
    • By downseast
      Hi everyone
      When I go to start it clicks as if there is a hydraulic lock and wont turn but after two or three attempts it then does turn over and start but I need to give it a bit of throttle to start – is this normal ?
      I haven’t changed the Lambda
      sensor yet, anyone know how much difference this might make ( I have a new Bosch universal to fit )
      I believe the T Boss was worked on by the previous owner
