2022 Mule Pro-MX EPS LE - Wiring diagram / ACC wire connection location
Cole
Go to solution Solved by Cole,
Hey everyone, as the subject says I have a 2022 Mule Pro-MX EPS LE and need to know where to connect the ACC wire for a switch panel I bought. The switch panel has 6 buttons to be able to wire up light bars, wench, radio, etc... This will allow it to only receive power when the mule is on instead of my radio being left on draining my battery for example.
Under the seat are 2 fuse boxes next to the battery. On one of them is a fuse labeled ACC - the backside of it has what appears to be 4 wires going into it. I assume I can splice into one of these 4 wires for the ACC wire for the switch panel, just not sure which one and having a hard time finding a wiring diagram.
Am I on the right path here or is there a better location to wire in an ACC wire for this?
    • By kadams428
      Recently my four wheeler has had an issue of being set in gear and it begins riding on its own (up to 3-4MPH). It also is having difficulty shifting into different gears after riding in one gear (i.e. going from reverse to high gear). It will shift perfectly fine when shut off, but consistently has both issues stated above.
      Previous research has shown me that it could be an issue with belt tension/deflection, however I have been unable to figure out how to do that with these machines. I've seen some clutches have a jam nut and all that is needed is a wrench and an Allen key to make adjustments, but I haven't seen/found that on the 600 clutches. Has anyone done this in the past or have knowledge of how to accomplish this?
    • By sxr951
      parts for massimo, hisun,etc in florida? where can i get parts for the massimo 700.. like bolts and console i  didnt see any bolts on amazon to go with cylinders and any thing when rebuilding a 700 engine
    • By mac66
    • By Ronald
      Check engine light comes on after engine runs continuously for 5 minutes or so.  I can shut down the engine and restart and check engine light goes out, then comes back on after running 5 minutes or so?  What ya think?
    • By FGT
