if
  On 4/3/2023 at 2:49 PM, T-boss 410 said:
Oh OK. I gotcha now. I'm just curious if there's a reliable switch to be had out there,
Expand
all you should need is a good Three position switch. Off/Run/Start.
if i was looking at the correct switch online, there are only 4 wires that go to it, just find out which ones need power  or ground in the Off/Run/Start.
Thanks. I guess what I have been trying to ask is, are there any particular brands of switches that are better manufactured so as to know that the switch purchased is a good functioning switch? I've not had to replace ignition switches much in the past, except for riding lawn mowers.
starter solenoids typically only draw No More than 10 Amps.
i remember when i got the new starter for my mule it came with a data sheet and solenoid amp draw was like 5 amps... if i remember right.
OK, thanks. Now I have another question. Every video and wiring diagram I have seen says to install a 30 amp fuse in the wire from the + side of the solenoid to the relay. Not sure why, and it's not explained. However, this has been on riding mowers. Does that make a difference?
Thanks 😊
    • By The Road Hound
      Hi,
      New to the forum.
      Came here looking for some experienced UTV users who can enlighten me about which brand should I pick for my very first UTV or SXS.
      I'm between 3 brands and 3 models:
      *Kawasaki MULE PRO-FXR   1000.
      *Yamaha wolverine rmax2.
      *Can am Commander XTP.
      The use I'm willing to give it is mostly to go to the range with my wife, load steel targets and all our shooting gear, we shoot a lot, rifles, Shotguns and Handguns for practice, training and competition. (Range is about 10 miles from home)
    • By allinone
    • By TexAcoon
      I'm looking to purchase a 2015 Massimo 550 that might have an issue with it's throttle position sensor.
      From the fella selling this UTV, he claims its to set the idle on fuel injection because the engine will not stay idle or when it starts sometimes it idles too high.
      My Question if anyone had any issues with their Massimo 550 and if it was actually the TPS or something else that would allow the machine to idle correctly.
