if
7 hours ago, T-boss 410 said:
Oh OK. I gotcha now. I'm just curious if there's a reliable switch to be had out there,
all you should need is a good Three position switch. Off/Run/Start.
if i was looking at the correct switch online, there are only 4 wires that go to it, just find out which ones need power  or ground in the Off/Run/Start.
Thanks. I guess what I have been trying to ask is, are there any particular brands of switches that are better manufactured so as to know that the switch purchased is a good functioning switch? I've not had to replace ignition switches much in the past, except for riding lawn mowers.
starter solenoids typically only draw No More than 10 Amps.
i remember when i got the new starter for my mule it came with a data sheet and solenoid amp draw was like 5 amps... if i remember right.
OK, thanks. Now I have another question. Every video and wiring diagram I have seen says to install a 30 amp fuse in the wire from the + side of the solenoid to the relay. Not sure why, and it's not explained. However, this has been on riding mowers. Does that make a difference?
Thanks 😊
Wouldn't be any different for a riding mower.
Possibly if for whateve rreason the solenoid trigger wire shorts to ground. Or the relay becomes stuck. which is super rare.
    • By SouthernGypsy
    • By JSwearer
    • By se3388
      Steve.............
    • By Texjpr
    • By mark walkom
