Product for notifying other riders of emergency?
By boydog40
thanks guys
By Michigan sport.
I'm sure many of you are aware of Michigan's emergency brake requirement. I'm wondering if anyone has a good solution.
Beyond paying the few fab places $$$$.. I'm curious is there another rear caliper with e brake style that would interchange with slight mods to the Maverick sport rear mounting bracket?
By Howard Elmore
By Reynolds Rocket
By lmarkie
Any thoughts?
