I have been working on variations of the Clutching for the 6 Arm design and have had Outstanding results . The Test vehicle is a 21 Turbo RR completely stock. All changes are in the Primary Clutch . The 6 Arm clutch made more power than the P Drive (stock) after the 6 Arm was properly calibrated. Here is the final Dyno pull . This is the stock clutching vs. the Prototype Kit . Very Impressive ......Just wanted to show that you can get plenty of performance out of the 6 Arm clutch and not buy a P Drive . In Fact , i tweaked a P Drive and The Graph was almost identical when both clutches were ran ....Both of these clutches were ran on the same machine ....
9 hours ago, klm said:
wish I knew what you  are talking about.
Is it that you do not understand Clutching KLM ? Just wanted to Clairify .. That way I can make sure to answer you correctly ..
Thank you
    • By FDWT9956
    • By Cletus
    • By Steve Waldner
      I have a Kioti  Mechron utv and want to add power steering. Can anyone till me if there is an electric assist motor from a car that would work putting between the steering wheel and steering box. One that doesn't need alot of electronics
    • By Gerals
      I use my Hisun 550 (with the Coleman stickers), for general work around my 10 acres of hilly land. Hauling firewood, some dirt and mulch, and debris clean up. Also felling dead standing trees in the woods and hauling rounds out to the barn for splitting/stacking.
      Here's my question:  Those who use their UTVs with towed drag implements or snow plows, have you noticed any issues with early clutch slippage or failures?  Or premature belt wear?  Other drive line issues??
      Thanks in advance for any experienced thoughts and comments.
