  • Matt JB changed the title to Tracker 800 SX Anyone upgrade to lithium battery ?
Hope this message finds everyone well. My team and I produce and 12v lithium battery purpose built for off-road abuse. Check us out at www.golithium.com. I would love to answer any questions you may have.
- AJ @ GO Lithium
    • By Gorj
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Flanman55
    • By Gorj
      I am into five years of ownership of my electric side by side and I am noticing some deterioration of power. Although I measured the voltage at over 49 volts, I believe the batteries are beginning to fail. I charge them about twice a week. Last year the charger went out and I replaced it with a 48 volt golf cart charger.  What has been your experience with the batteries?
