Stuck axle in a artic cat 550 prowler front diff
By mcraigchr
Howdy y'all,
Craig C.
By camojay
By GaryC
By Rider
I have a 2021 Massimo T-Boss 410 and it needs the cv boots replaced. Has anyone had to replace the boots on their T-Boss? Does anyone know where to get replacement boots? Are there boots for other ATV/UTVs that will fit? The Massimo parts site only sells the entire axles. Thanks
