  • Alex changed the title to 2021 Tracker 800sx DUMP BOX
  • 1 year later...
    • By SouthernGypsy
    • By se3388
      Steve.............
    • By Greg Kilgore
      Plumbing parts list.
      2 1" x 3/4" x 1" PEX Tee
      1 3/4" PEX ball valve
      1 1" PEX ball valve
      Wide view of the plumbing.
      Kilgore.
    • By mac66
      The good...
      -Fairly comfortable to drive.
      The not so good...
      Overall Impression...
