I am in the process of installing turn signals and came across two 2 pin connectors upfront that are sky blue/grn and orange and grn.  those are the correct colors for turn signal wires but every post I have seen points you to the same color wires in the larger connector that goes to the headlight. I know they want you to buy the whole assembly but could the  2 connectors I found be for the side marker turn signals or do the whole assembly headlights make use of these two "pig tail connectors"
thanks
      Is there a diagram of all of the grease zerks for a Coleman UT 400?  Mine squeaks like crazy and want to try and remedy it.
    • By allinone
    • By Kingfish
    • By Jon V
      Good afternoon. When the timing chain came off its lower gear (previous owner had over-tightened the tensioner), I ordered new parts.. chain, oil-pump chain, tensioner etc.. But now that it's time to put it back together, the main crankshaft makes a clang noise and stops when you turn it by hand. I want to solve this before assembling everything. The camshaft cover is off so that the valves aren't being activated. Should the transmission be in neutral to turn the crankshaft? The engine was running fine until the chain came off the lower gear. Then it would spin when the starter motor engaged so I assumed the crankshaft was spinning. Any advice is appreciated.
