I was curious if anyone has ever tried to use aftermarket axles from one of the larger utv manufacturers in a Massimo?
my mxu is equipped with an up yours lift, and I would like to upgrade to some monster xp axles to help with the steeper axle angle.
I have spoke to the aftermarket axle manufacturer and emailed Massimo , but no luck yet on specific spline,length,O.D. Ect as of yet
    • By ToughLuck
    • By Joe Breaux
