98% of my S X S riding of the mule is on a paved black top road.  I have gone through two sets of treaded UTV tires, current tires are Carlisle.  Size of the tires is 23 X 11 X 10 and they are worn out.  I tried to buy a street tireson the last set but these were somewhere in between and they didn't last on asphalt and were somewhat hard on my lawn.    I have been able to fing a street tread thus far to fit my Kawsacki mule.  Hs anyone else found a good tire for street use?  Even the cheap treaded tires are around $150 each.  A golf cart style tire might work but I don't believe they come in my size.
You will probably need to get different aftermarket wheels so that you can fit road tires. I have a old 550 that came with 14" wheels that has 195/70R14 tires. Note that you may need to adjust the camber on the front to get even tread wear.
      I've been having misfire issues with my UTV 400 when it gets warm and I've thrown all kinds of parts at it so far with no permanent resolution.  Today I removed the O2 sensor and it is black on the end.  To me that means it's running rich and/or the sensor isn't working.  I replaced the sensor with a new one and will see how it goes I guess.  With EFI, I'm wondering why the sensor would be this way with low hours and mileage?  Is there a way to adjust or lean out fueling on these?  Thanks in advance.
    • By Gorj
