I was having a problem getting my utv to start.  I replaced the starter and everything was fine.  Yesterday I went to start it and it turned over a few times and then stopped.  When I went to start again the starter was spinning but not the motor.  I removed the starter and checked it and it seems to be turning backwards now.  I checked the starter gear and it turns freely in the same direction as the starter.  Any help would be greatly appreciated.
  • 4 weeks later...
3 hours ago, dholmes959 said:
I am going to try to change the starter one way clutch gear and then I will let you know.
Thanks. I think my starter motor is slowly turning in its notice. Changed out the battery today, but still not having the right response when key is turned.
    • By hisun junk
    • By Jacob E freeman
    • By Will Sutton
    • By Texjpr
