I was riding my Buck 400 and when going up a slight incline I noticed it dropped in power. Once I reached the top I made a turn and it stalled out. I have not been able to start it. When I looked at air filter the case was about 2 1/2 inches deep in oil and gas and filter was torn. I cleaned it out, replaced spark plug and drained oil. I added leak stop then new oil. It just had head gaskets replaced back in the fall. When I try to crank it, it sounds like it wants to start but it is not getting enough to start up. Does anyone know what could be happening with this UTV? I am stumped! I figured there is a bad seal for the gas/oil mixture to be in reservoir where air filter is. Hopefully leak stop additive will correct that for the time being until I can figure out what is happening. Please help.
Thanks in Advance for your feedback.
60 PSI. I am going to look at spark plug again, fuel injector and take off the cam cover to see if anything looks odd. If I don't see anything then I believe I will run a top end leak down. I hope that I can find the issue but afraid it is the piston and that will be an issue. Afraid if I take engine apart I will not find the parts I need to fix due to being manufactured in China. Lesson learned for me. any suggestions are welcomed. Thanks
Register a new account
Sign in
    • By Cletus
    • By allinone
      Have a bed decal that has never been right.  Contacted Coleman Powersports and they have no solution.  Anyone know of a place where I could get a replacement decal or complete decal or graphics kit?
    • By Steve Waldner
      I have a Kioti  Mechron utv and want to add power steering. Can anyone till me if there is an electric assist motor from a car that would work putting between the steering wheel and steering box. One that doesn't need alot of electronics
    • Get More For Your Device
      Is there a diagram of all of the grease zerks for a Coleman UT 400?  Mine squeaks like crazy and want to try and remedy it.
