Posted (edited)
New to the side x side experience.  I bought a Coleman 550 Outfitter and I've seen conflicting comments about whether to use high or low range for running around under 15 mph.  Comments?
Edited by Clint
Left out make and model of machine
  • Clint changed the title to High or Low Range Coleman 550 Outfitter
  • 1 year later...
The biggest issue with anything with a wet clutch is running at speeds where the clutch is barely engaged. Doing that, and putting strain on it can cause the clutch to slip causing excessive wear. Once it starts to wear from slipping it gets worse quick. These cheaper UTVs seem to have weaker wet clutches anyway, anything you can do to avoid that wear is a plus.
You should run low range at lower speeds (below say 20 mph) or repeated start/stop conditions. High range is for faster continuous trail/road driving.
    • By SkyPilot56
    • By UTVLover253
      What you love about it
      What frustrates you
      – Adam
    • By Xov
