Anybody out there change a head gasket on a 2014 700? Really confused as to which one to order. Same # 2 different gaskets. Different water jacket holes. I get # 12250-007-0000 comes up with different hole pattern for coolant. Can you use a yamaha gasket?
Posted (edited)
dont know about 700 but my mechanic used a Yamaha gasket on my 17  MSU 500.. The HISUN engine is a 95% clone of Yamaha  RHINO  engine  ..
Edited by Joe Breaux
dropped my cigar
    • By Gorj
    • By Grant
    • By mcraigchr
      Howdy y'all,
      Craig C.
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Greg Kilgore
      Got a 2021 Axis 500.
      Manual states 38nm.
      Anybody got the answer?
