Havoc VS Stampede Motors
By Mmcleary
By Paul L
By Greg Kilgore
Got a 2021 Axis 500.
Manual states 38nm.
Anybody got the answer?
By Bloodhound
Any info on the duribility and reliability of these don't know the size
