Posted (edited)
I was having a different spark plug issue and I hooked it to a charger and with the fans running it drained the battery down. The temp gauge never gets over the lowest it can read. The fans even run after shutdown. I know it will heat up if it’s not cooled after shut off but it never seems to get hot & im pretty sure it’s killing batteries. It’s even so loud it’s annoying. I’m just wondering if any similar incidents have occurred before I trace the wires and get into a big job.
Edited by Aaron Miracle
Misspelled a word
    • By Gorj
    • By aefron88
    • By Grant
    • By clint501
    • By Matthew Smith
      2013 Bennche Bighorn 700 EFI
