I have taken my engine out and am doing a complete rebuild due to issues I had with piston. Since I had to get that deep into it I decided to change ALL gaskets as well as piston and piston rings. Now I am having an issue finding the right parts. Called Parts Boss for help but they keep telling me someone will call me back, but no one does. Can anyone point me into the right direction to find someone who can supply all the gaskets, rings and piston for a 2020 Massimo Buck 400 EFI? I called Massimo but they no longer stock parts for this UTV. Need help!
Jon
Wow! Only 3 years old and they don't stock parts? That sucks!
Who is the engine manufacturer? You could check the manufacturer's website if available, or check a website called Motorcycle Doctor.
The engine is most likely made by either Hisun or Linhai. I believe both have their own websites.
    • By Dennis
    • By Gorj
    • By Bobbers
    • By aefron88
    • By SSgt1994
      Myron
