2014 massimo 700 efi. Looks like idle screw has been messed with. Any techs on here know how to get back to factory setting? This is driving me crazy. What you get for buying used I guess.
Are you talking about the idle speed adjustment or the idle air adjustment? Mine (2019 T-boss 410), has an idle setting of 1200 rpm's. If it's the idle speed adjustment, I would turn it in until it stops, then turn it out 2.5 turns and start from there. That seems to be the common starting point on automotive carbs.
Efi not carburated. Someone has it way screwed up. Just trying to get it to factory so tps can find home. It's searching but can't find the spot. Should not adjust but no choice.
    • By Joe Breaux
    • By SteveS
    • By Adrian Domingues
      Thanks for your help
    • By strike250
      Matt
