2017 Massimo Alligator 500 cant keep timing chain on bottom sprocket
Go to solution Solved by Ben1098,
  • inkjunkie61 changed the title to 2017 Massimo Alligator 500 cant keep timing chain on bottom sprocket
  • Solution
Shine pen light into chain and lower sprocket cavity.....just to be sure the chain in on the sprocket.  Keep tension on the chain and tie a nylon twist string (not braided as they do not stretch) to the "top" of the timing chain with the other end tied off on the roll cage.  The top tie point must be very close to the position the cam gear will install to.  Slide in the cam gear and milk the chain around the gear and then keep the chain and gear tight so the chain cannot jump of the lower sprocket.  Mount gear to cam and verify the timing dots and sling weights.  The 3 hand fix.   BEN
    • By GBarney
      Recently bought a 2010 RTV 1100 with bad engine. a d1105T out of a toro 5400 just came available locally. Looking for info on if anybody has installed the turbo version of this engine, what challenges/ problems were encountered, how it turned out.
    • By Gerald Mohs
    • By staind
      thanks Dan D. aka staind
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Roadstar515
      Regards, Rick
