DO NOT BUY ANY THING FROM HISUN Period! I had the axis 700 for 2 months when a rat or squirrel ate both wiring harnesses. (Main & ECM)Wanna know why? Because the manufacture of these things in their infinite wisdom use either, a soybean oil or a peanut oil to run the wires through the the wire loom. Hmmm i wonder why they would be inclined to eat the wires. So now I have $10K machine that I've only had for 2 months when all this happened and they will not warranty it at all. It is going to cost me $800 to $1000 to get this fixed. Here is a link to a video showing where we took our Hisun notice how many are there:
https://photos.app.goo.gl/2FdniAoCyvTJMKae7
So counting mine, there are 16 of Hisun Axis on the lot that i took in for authorized dealer, with the exact same problem, plus other troubles that the mechanic explained to me. This particular place told me they are not going to work on them anymore. I will be posting this in as many places as possible to reach the masses. I hope its worth Hisun!
that is true.. We have a Jeep with the 4.0L six .. it leaked from every gasket.. BUT, not until 180,000 miles.. after I replaced pan, rear seal ,timing and valve covers, no more leaks..  Whereas  HISUN leak on the boat from China . AND  If a car leaks on day one, the Dealer will fix it.. Hisun will never fix anything. Their warranty is written on toilet paper so you can at least use it to wipe your butt
    • By Flanman55
      I have purchased a used Supermach700 (2008), It runs great after a new choke cable but. The temp sensor on the thermostat house is unhooked and can not find where it plugs back in. The fan has been un hooked from the sensor in the rad and cant figure out how it goes back together properly.  The fan was wired to a by pass switch and i just always leave it on but would like to work it properly. I assume the sensor went bad and not changed.
      any help would be great.
      thanks
    • By BigWave
      Bigwave
    • By Chile
      Chile
    • By Joe Breaux
    • By Aaron Colona
