that is true.. We have a Jeep with the 4.0L six .. it leaked from every gasket.. BUT, not until 180,000 miles.. after I replaced pan, rear seal ,timing and valve covers, no more leaks..  Whereas  HISUN leak on the boat from China . AND  If a car leaks on day one, the Dealer will fix it.. Hisun will never fix anything. Their warranty is written on toilet paper so you can at least use it to wipe your butt
    • By Marie
    • By Edelbrock
      Thoughts?
    • By Unhappy Kioti K9 Owner
    • By KnS
      Hey Team, our issue is not as bad as some I've read here...  We put some songs one a 64GB USB stick, plugged it in and the USB icon is still greyed out and won't let you select.  Any suggestions?  All the songs are in the root directory.  Thanks, Kevin & Shelbie
      Any thoughts ?
