2016 750efi new fuel pump supposedly...didn't run for 2 years changed plugs and battery ran good for about a hour died then drained battery...cleaned ground wire because it looked a little dirty charged battery now it will run but only if I'm giving it gas and randomly exhaust will glow red then cool back off...I'm thinking either tps or possibly valves or something electrical also curious if the exhaust system could be slightly clogged any info or pro tips would be cool just trying to get it going for a yard work type rig
  • Alex changed the title to 2016 Intimidator 750 efi Won't idle hard start?
Might check spark arrestor in muffler. Not familiar with your particular machine but I would assume it's like most others. If screen is coated with carbon build-up, just burn it of with a torch and wire brush. Good luck!
    • By CapnWalleye
    • By CapnWalleye
    • By Gorj
    • By SteveS
