Was running fine low hours purchased new. Started and drove out back of the barn. Went to start it after doing some work and it will not fire. Only way I could get it to fire was to go in neutral and hold gas pedal down. Have to keep giving it gas to run.  Will not idle. Just quotes when I let it
go to idle
Hi Steve!  Similar to you, except mine only did it when it was cold(ish).  If I kept it running and the engine warmed up, ran fine.  Since temps are better since spring, haven’t had the issue.  Wish I could help you more
  • 3 months later...
I think that’s prudent.  I use only ethanol free in mine.  I partially turn the key, to run fuel pump, needle moves to far right, then I I press brake pedal, and fully turn key to start.  I then wait until the check engine light goes out, before driving.
    • By downseast
      Hi everyone
    • By Rick A
