Tracker 800sx
Picked up an essentially new 2022 UT400 with 9 miles on it. Decided to change the oil because it's probably never been done. Pulled the dipstick and noticed it was overfull then went and pulled the drain plug and took off the filter and it was like brown water running out. What should I start checking?
By JSwearer
Does anyone have any suggestions for aftermarket shocks. I have a T-Boss 550 and took it riding in some rough trails and the stock suspension was uncomfortably rough.
By mark walkom
By Gary Gallo
By Paul in Wisconsin
I have a 2023 Tracker 800SX LE that I want to add a sway bar to.
The service manual shows how to remove and reinstall the sway bar.
I called Cabela's to try and get the saw bar. They said they can't get one and the 800SX doesn't have one!!?? Then why is it listed in the service manual?? No answer from them.
Have any of you found a saw bar that fits and what did it cost?
