Hi, we are in the UK and have several Vector E1 to look after and one is showing a code of 45c2 which is to do with a BDI, presumably battery Discharge indicator? and the vehicle moves about 10 feet, stops and has this code, any idea's anyone?
      Greetings All,
    • By Gorj
    • By aefron88
