2022 hot seat Pioneer 1000-5 trail
By A P
I have a 2022 hisun sector eps 550. 30amp fuse is blown for eps. Checked the motor and it’s fine. Opened up the controller and found a bad diode. Dealer wanted 500$ for the controller. Just posting this in case it helps someone. I couldn’t read numbers from the old one so just took a guess and replaced it with a 100v 3amp diode.Â
By CYJSP2009
Dear Friends,Â
2022 Brand new Joyner CV Axles and CVÂ Joint rebuild kits are commingÂ
1. S650.03.02.02.00 ---Joyner 650 Commando Rear
2. TR1100.03.01.03.00 --- Joyner Trooper FrontÂ
4. D650.03.02.02.00 --- Joyner 650 Sand Spider Rear LeftÂ
5. D650.03.02.03.00--- Joyner 650 Sand Spider Rear RightÂ
7. 14274 --- 650 ider rear left, rear right, 800 MV; 800Viper, SV1100 Drive shaft rear left and rear right outer cv joint rebuild kit
8. 15803Â ---Â 650 Sand Spider rear left, rear right, 800 MV; 800Viper, SV1100 Drive shaft rear left and rear right outer cv joint rebuild kit
Attached are the part photos for reference.Â
Above parts are now on the way to USA, will be ready for inland delivery in middle of July.Â
Price: CV Axle: USD250/ Piece; CV Joint kit (without grease): USD110 send to door.Â
There will be special discount availabe for deals completed within July 2022. Â
Buy 1 piece: Get 5% discount,Â
Buy 3 pieces: get 15% discount,Â
Buy 4 and more than 4 pieces: get 20% discount.Â
Please kindly note Qty for each part is not big and it is hard to forcast when there will be next offer for these kind of products unless there is sufficient confirmed order qty for productioin arrangement.Â
Payment method: Payoneer payment link ( can pay through bank account or credit card) or Paypal ( [email protected]) . Payment commission paid by the buyer.Â
Interested parties, please contact [email protected].Â
Good Luck
Casey / Leaf Asia
July-07-2022
Â
Â
Â
Have a Coleman UTV 400 that cranks, runs, drives well until it gets warm and is put under load. Light throttle or full throttle it doesn't bog, but it will cut out mid throttle if you move the pedal quicker than it seems to like for example when you're getting ready to go up a hill, but if you immediately floor it, it will do just fine and not cut out. It's random if and when it's going to do it, but is consistent in that it happens only when hot/full operating temperature. I've replaced the injector twice, same with the spark plug and tried different heat ranges (NGK 7,8 and 8 iridium), replaced the fuel pump, adjusted the valves, checked air filter which is like new, changed the oil, replaced the fuel filter. No check engine light. I don't have a code reader for this. Initially I thought it might have a head or head gasket issue as when I got it, the oil was over full, very runny like water milky and it was smoking. I've changed the oil since then twice to clear and clean everything out, and it seems to be good. Coolant stays the same level and so does oil with no changes in consistency or need for adding more. Had I think 7-9 miles when I got it and now has about 77. What should I try or consider next? Â
By GunnersTacklebox
Â
The issue I've had is if I leave the utv parked on any incline, not even a major incline, and leave it to sit for a while (day or two) it will not start properly. It will turn over and not fire until I press the gas pedal, when it will run and rev up, but if I let off the gas it will die. It will keep doing this until I either start it in gear and drive it for a bit or leave it in neutral and roll it down the hill to flatter ground. where it will have to sit for a while.Â
If I park it on a decline there is no issue. fuel is not low, it's occurred a couple times now.Â
Â
Any thoughts on the cause of this? Dealership just says bring it in and let them take a look, at my expense of course.Â
By Roadstar515
Regards, Rick
