I have a 2009 Joyner Trooper 1100. I found that the Joyner Trooper ball joints were very poor quality, so I simply bought a similar size ball joint and the angle reamer, and they are much more robust. I find that with my trooper, a few things are just not made well and can use a few design changes. By in Large, the trooper is a very hardy machine and can be run trouble free if you don't treat it like a 1100 lb dune buggy and take it out jumping , etc.
  • 4 weeks later...
Rubber ball joints: These are the most common type of ball joint and are made of a rubber sleeve that is molded around a metal ball. Rubber ball joints are relatively inexpensive and easy to replace.
Polyurethane ball joints: These ball joints are made of a polyurethane sleeve that is molded around a metal ball. Polyurethane ball joints are more durable than rubber ball joints and can withstand more wear and tear.
    • By Gerald Dillman
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By Bobbers
    • By CYJSP2009
      Dear Friends,
      Buy 1 piece: Get 5% discount,
      Good Luck
      Casey / Leaf Asia
      July-07-2022
    • By staind
      thanks Dan D. aka staind
