Can anyone help me find the starter relay on my 2014 mule 4010?  The book I have says it is under the dash, but the pictures in the book seem to be by the fuses under the seat.  Either way when I turn the key to start the starter circuit relay engages but the starter doesn't do anything.  I want to check that relay before going to the starter.
One thing I noticed is the positive battery cable goes directly to the starter, so I wonder if this year doesn't have this second relay.  There is a signal wire to the starter I assume from the starter circuit relay which is driven off the key switch.
all you need to check to see if your starter relay is working, is to pull the trigger (signal) wire off of the starter solenoid and check to see if it has 12V with the key on in start position.
    • By Some random dude
      2015 Hisun 700 Utv
    • By Tom Gorski
    • By Sando
