Kymco UXV500I/UXV700I Service Manual
This manual has been designed to assist trained mechanics in servicing the models listed above. If you do not have the proper training or tools to perform a particular task it is best if you seek out a service professional.
This manual was written using the latest information available at the time of publication. Illustrations in this manual are shown to help you with the basics of performing the jobs listed. The pictures in this manual may not depict the actual vehicle you’re working on, however the procedures will be similar.
Inexperienced technicians without the correct tools and knowledge may not be able to perform these jobs as intended. Caution needs to be taken for the vehicle and its operator as serious injury can occur. Always read a procedure in its entirety before attempting any repairs.
  • Submitter
  • Submitted
    07/09/2023
  • Category
    • By strike250
      Matt
    • By Jim Kessell
      Hi All
      Jim
    • By gwares
      The Kymco CV3 is a pioneering three-wheeled maxi-scooter that combines the agility of a motorcycle with the stability of a trike, catering to riders seeking versatility and performance. This can be ridden on a car license!
      Key Specifications:
      Engine: 550.4 cc parallel-twin, liquid-cooled
      Power: 51 bhp (38.1 kW)
      Transmission: Continuously Variable Transmission (CVT)
      Fuel Tank Capacity: 15.5 litres
      Seat Height: 795 mm
      Dry Weight: Approximately 280 kg
      Brakes: Dual front discs and single rear disc, equipped with ABS
      Suspension: Independent front suspension with dual leaning wheels; rear mono-shock
      Wheels: Front: 13-inch; Rear: 15-inch
      Everything works and new!
      WhatsApp: +33 758 56 21 59
    • By gwares
      Price: 4000 EUR
