I went to the local muffler shop and purchased a QUIET cherry bomb muffler. Auto Zone has all the nessary connections & clamps. Installed and it is as quiet as the little old lady driving to church.
rocmoc n AZ/Mexico
I used the stock endpipe from my yamaha r1. Titanium so it's light and dead quiet. The loudest thing on the engine now is the fan. if you go to r1forum.com I'm sure there are a hundred people on there with aftermarket exhausts that will give you the stocker for next to nothing.
How about a photo?
Kinarfi
    • By Unhappy Kioti K9 Owner
    • By Marie
    • By Frank Mac67
      - NO CLICK - NO OTHER NOISE
      Can anyone help?
      Can anyone help with this?
