Any one tell me about setting the clock in my Textron???    I have a Faul code 5.  Any one know what it is and how can I clear it.    It is nicest side by side I have ever had, handles great, I have not had it off of blacktop or gravel yet. Plenty of power with the 80HP German engine.
    • By Mmcleary
    • By Unhappy Kioti K9 Owner
    • By aefron88
