Posted (edited)
I would likeI would like to add some electrical gadgets. They've done a superb job of concealing the wiring.
I would to add some electrical gadgets. They've done a superb job of concealing the wiring.
Can someone I would like to add some electrical gadgets. They've done a superb job of concealing the wiring.
Can someone please give some tips on accessing the dash and wiring?
It looks like the plastic...please give some tips on accessing the dash and wiring?
It looks like the plastic...ld like to add some electrical gadgets. They've done a superb job of concealing the wiring.
It looks like the plastic...to add some electrical gadgets. They've done a superb job of concealing the wiring.
Edited by Alex
corrected text format
  • Alex changed the title to 2019 Kawasaki Teryx KRT 800 wiring
    • By Kingfish
    • By hetovi
      Hello everyone.
    • By BernieG
    • By Jhud
      In the market for side by side. Narrowed it down between the pioneer 1000 or defender Hd9. Looking for pros and cons of both. Any info would be helpful in my selection process. Noise, speed, reliability, ride, all of it.
