Volt Meter
By Matthew Smith
2013 Bennche Bighorn 700 EFI
Figured I’d check for spark and compression while I was dorking around. Compression is 110 psi, but there is no spark. Replaced the spark plug… no change.
By Gorj
I am into five years of ownership of my electric side by side and I am noticing some deterioration of power. Although I measured the voltage at over 49 volts, I believe the batteries are beginning to fail. I charge them about twice a week. Last year the charger went out and I replaced it with a 48 volt golf cart charger. What has been your experience with the batteries?
By D MAYNARD
By Rainman
Thanks in advance ...
