I'll have to get some pictures this weekend of what I did.
I used a glowshift GS-TCD06 gauge along with mounting bracket GS-U1UDB. The raditor hose T I used is in the thread I provide purchased on Amazon. I did bore the center of the T adaptor some because I didn't want to restrict the coolant flow. I also drilled and tapped the adaptor to accept  a  1/8" NPT to 1/4" NPT reducer to keep the temperature sensor from filling up the inside of the adaptor.
Here are the pictures as promised. The fuse block is well a fuse block connected to the battery, and the terminal strip is connected to switched power. The picture of the adaptor shows how I drilled tapped to a larger NPT thread to raise the sensor out of the direct coolant flow. I contacted Glow gauge tech support and they said it was perfect.
17 minutes ago, Hollywood said:
Thanks looks great. Doing it just the way you did.
Also, forgot to mention I placed the sensor adaptor in the top hose. You can see when the thermostat opens and closes. I used two clamps to pinch the hose and didn't lose  any coolant.
    • By SouthernGypsy
    • By se3388
      Steve.............
    • By Greg Kilgore
      Last year bought a small universal coolant style cab heater. Well I installed it today. Thanks to another member, RangeRider45, and his install
      That told in his post the size fitting he used. I got the same fittings plus a few others. And all went kinda smooth. Took a few minutes to get air purged from coolant system. Should have parked on hill with front up in the air. But would have had a hard time working on it.
      I had a variable power switch connected to an overhead cab fan. Never really used the fan that much. And I have to remove the fan to put on my cab enclosure anyway. So I repurposed the switch to supply power for the heater. The heater has 2 12-volt DC computer fans that are rated for 1.8 amps each. So it's not going to be a big drain on the weak charging system. And with the switch I've got great control over the speed of the fans.
      If anyone is interested the radiator hoses are 7/8 inch. I reworked the temperature sending unit (moved it closer to radiator) to make room for all the extra plumbing I did to get the heater to work the way I wanted.
      Plumbing parts list.
      10-15 worm water clamps. 3/4 to 1 1/4 inch size.
      2 1" x 3/4" x 1" PEX Tee
      1 3/4" PEX ball valve
      1 1" PEX ball valve
      5/8" heater hose. I got 6' and probably have 4' left over.
      I used the radiator house I cut out to use as splices between the PEX fittings. The PEX fittings are not true to their dimensions that are stated on the package. So they fit the 5/8" and 7/8" very nicely.
      They way I have it plumbed is from radiation out side. A tee, then the 1" ball valve, then a Tee. Coming off the Tees are the hoses going to the heater core. There is a 3/4" ball valve on one of the Tees. The ball valves are used to bypass the heater core in the summer. Or direct the hot coolant through the heater core in winter. The temperature sending unit tells me how hot the coolant is. And if anything is getting too hot. The dash also has an idiot light that comes on if the head gets too hot. But doesn't do anything if the radiator gets too hot. There is a temp sensor on the radiator that controls the electrical fan. But if the coolant isn't circulating. That switch never sends a signal to turn on the fan. But enough talking/rambling. Everyone wants to see pics. The only thing I need to change is the orientation of the handle on the 1" ball valve. I have 2" or more clearance between the handle and the tire when cut hard right. But I still don't like it. And instead of taking the valve out and rotating 180°. I'm just going to take the nut off and rotate the handle 180°. Think I need to make a locking mechanism to lock the handles in place so they don't vibrate closed when the machine is moving.
      The temperature sending unit and housing. Size 22 mm. Aluminum from Amazon.
      Upper Tee the lower Tee is identical. Can also see the handle of the 3/4" ball valve on the 5/8" hose going to the heater.
      The 1" ball valve. Goes between the 2 Tees
      Wide view of the plumbing.
      The heater installed in the sxs. The 3 black hoses are just hanging there. Zip ties to the heater but not attached to any thing. Will probably just direct 2 toward the wife's feet. And 1 toward mine. Or what ever is need as the heat is needed on rides. The black hose in passenger floorboard is some 1" hose that is not needed. Don't know what I'll do with it.
      I think if I was going to do it again. I'd put some Indian Head gasket dressing or silicone on the 1" side of the PEX fittings. And I may still do that. But I really hate the ideal of introducing air back in the coolant system.
      Any questions just ask. It may take a while to answer. But I'll try.
      Ya be good and stay warm over the next few months
      Kilgore.
    • By MMaster
      does anyone know of a replacement temp gauge that will work on a joyner 2016 r4, my gauge has condensation in it and it quit working
    • By MMaster
      looking for a replacement  temp gauge that will work with my joyner r4
