2006 Joyner 650 Cv axle
Jwiens
  • Alex changed the title to 2006 Joyner 650 Cv axle
On 8/3/2023 at 9:37 AM, Jwiens said:
Looking for a left (driver side) rear axle for a 2006 Joyner 650 sand spider. Or any alternative axles that would fit.
Hi Jwiens,
I have the rear left cv axle you are looking for.  Please refer to attached photos.
Please send me email at [email protected] for further discussion.
Best regards
Casey/ Leaf Asia
2023-08-04
  • 4 weeks later...
On 8/4/2023 at 9:49 AM, CYJSP2009 said:
Hi Jwiens,
Best regards
Casey/ Leaf Asia
2023-08-04
Been trying to email you for days now. I keep getting [email protected] is invalid email address and it won’t let me send. Can you email me at [email protected] if you see this? Was wondering if you have this (outer ) cv joint rebuild kit for my 650 sand spider rear right passenger side?
Hi Bachelor51,
I also tried to send you emails but get no answers.  [email protected] is still in use. I received email from customers today including the UTV Board notification email of your quotation here.
As per the cv joint rebuild kit, it is still available.
Could you please send me another email using another email address of you?  I will use another email address of mine: [email protected] to send an email to you again. Let's test both ways.
Best regards
Casey / Leaf Asia
2023-09-02
6 hours ago, Bachelor51 said:
Yes I just need the cv joint repair kit. My axle was good when disassembled. If comes with everything in this picture, that’s definitely what I need.
Yes, this cv joint rebuild kit is available. I will issue payment link and send to you as we did last time for the cv axle. I will arrange shipment and send you tracking number once payment arrives.
Hi Bachelor51,
Please check your email from Payoneer and proceed payment. I will arrange shipment and send you tracking number accordingly. Thanks
Casey
2023-09-04
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By Travis M
      Just purchased a T-Boss 760 and before putting any miles on it I'm going over all the fluids, grease and problem areas that I've read about online because I know the factory quality control is garbage.
      I've seen where everyone seems to have leaking axle seals after 2-300 miles on the T-Boss 550 and 760. I think I'm going to switch from the bellow-style diff breather to the automotive style diff breather that they use on my Tacoma and various other vehicles. I'll still keep it extended and infact run it even higher, probably into the air intake box, but I'm hoping this is what's causing the axle seal leak issue on these vehicles.
      I'll do the modification and report back every couple hundred miles and let you know. I currently only have 8 miles, so it will be a few months before I find out if mine leaks like everyone elses.
    • By joynersfuntillitbreaks
    • By Brett
