RZR HD Front Bumper with winch mount
By Karlibob
By Robbie Wyre
By KimAC
I need a pair of front shocks for a Landpride Treker 4200NT, from 2005? Does anyone know of a good salvage yard - or another source?
-Kim
By Alien10
A while back I was looking at an auction UTV plow and the mounting of it. Looked like it had an "H" bar with two pins that hooked into brackets on the front frame of the UTV. I have a bunch of 1/4" x2" angle iron, and some 2"x1/2" flat stock in the barn. I was thinking of welding up a bolt on implement mount that would provide 2 holes about 14" apart, that pins could be used to hook up an "H" frame for a plow or even a straight bar across with pins to hold it in place. The angle iron "A" would utilize the existing bumper mounting bolts front and bottom, and have the two channels "B" with holes for individual pins or one large bar across. Those channels would be welded to the ends of the angle iron.
Anyone ever try this for a front mount? It would be close to this one that is for sale on the net. It is supposed to fit a KFI plow mount.
By Dale Halifax
I'm a newbie. While I'm testing out my new to me 2021 Massimo T-Boss 410 winch, I broke the Orange Ring that fits around the cable. I can't see much of a purpose for this ring, other than to be in the way, and to break. Is this ring really necessary? I did find it on the Massimo winch parts diagram, but I'm thinking, Meah? Am I wrong? (It's # 13 and 14 on the parts diagram, attached)
Thanks.
