The Hisun Sector E1 is a nice electric unit.  Is there any way to remove or adjust the speed limiter.  It's limited to 25MPH so it will be considered a slow moving vehicle. But in my province it can not be driven on the road even with a limiter and triangle. So I'd really like to get a bit more speed out of it.
Not really a possibility. You may get a couple of MPG. The motor has only one bearing (like the Ranger  ) and uses the gearbox input shaft as the front bearing .  Upping the RPM by anything significant really does need a better bearing / front support and the field weakening mapping would need changing to get the Higher RPM. It also would have a lot lower power output at the Higher RPM. They really are what they are, and anything significant would take a lot of rework to achieve it.
      Is there a way to bypass the seatbelt speed limiter?
    • By BigWave
      Bigwave
    • By GunnersTacklebox
    • By Mike Jenkins
    • By HighSon
