I have a Tracker 800sx and am looking to install a time rake to help cleanup the forest floor on my property. My UTV has a 2” receiver on it. Anyone have any suggestions?
Thanks for the link. Picture shows some sort of implement attachment. Now I’ve got to figure out where to get the attachment piece. Do you have experience with the rake (link) you sent me?
    • By SouthernGypsy
      Here's my question:  Those who use their UTVs with towed drag implements or snow plows, have you noticed any issues with early clutch slippage or failures?  Or premature belt wear?  Other drive line issues??
    • By Duncan
      I got a utv from lowes it has one tire in the back that is the same size as the front tires so it has 3, 26-9-14 and 1 26-11-24. i want to change the rear tire to the same one as the other.So instead of buying a new rim will a 26-11-24 tire fit on a 26-9-14 rim.
    • By Robby
    • By JSwearer
