I was wondering if anybody have put xzilon on there car I bought a suv and they ofter to xzilon the inside and outside of it should I put it on or not it cost 600.00 to do it if you had to pay for it
I had the xzilon done to my new suv they gave it to me free when I bought the suv all I can say is WOW what a big differents it made it really shines it comes with a five year warranty. If I had to pay for it I wouldn't had it done 600.00 is a lot of money but it does look good
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Kingfish
    • By Browner010
      Recently I had an overheating issue on my 2022 Coleman Outfitter 550 (Hisun UT550) and to check to make sure it was fixed I took it out for a ride around the block. After a couple cycles on the LED coolant meter, I took it for a couple mile ride and on my way back I heard a loud metallic snap then a grinding noise. It was still able to move under its own power but very slowly. I was about 2 blocks from the truck so 'I limped it home and up onto the trailer. I know I need to tear it apart and look for what broke, but anyone have a guess as to where to start? I'm seriously getting tired of this damn machine! 750 miles on it and already replaced the belt, wet clutch, primary clutch, clutch roller weights among a few other things. Seriously, this friggin machine has spent more time on the lift than on the road. I thought I bought this new because it was from the owner of a tractor supply, but he registered it under the stores name making me the 2nd owner voiding any and all warranties.
      Any Ideas what to look for would be appreciated.
