    • By Smittay
      I saw that Intimidator is offering a $7k rebate on all their UTVs. This looks like an amazing deal. Are their UTVs any good? I looked through the forums and there appears to have been some problems in the 21-23 timeframe? Does anyone know why in the world they would be offering such a steep discount?
    • By Greg Kilgore
    • By Jacob E freeman
    • By Hutch
      I added lights to the Coleman Outfitter 550 last fall.   I bought lights on line from Nilight, a 300 W  12" light bar mounted forward and 2 square 4" floods for the rear.  Those are mounted on the roof corners facing rear and downward just beyond the tailgate.  Nilights seem to be of high quality, as I've had them on my garden tractor for 5 years and still flood the way ahead with great light.
      Both the front and rear lights provide amazing illumination making the OEM headlamps look like parking lights.  Made a connector for the front bar that plugs into existing headlamp switch so it is just part of that circuit controlled by the headlamp switch.   Rear work lamps were wired in using a rocker switch installed in the dash.  Backed up to the garden with the work lights and was able to harvest some tomatoes well past sunset.
      What have you used if anything for auxiliary lighting on your UTV?
