ok so i have replaced everything ive got just about 9 or so volts to the wire at the  coil then it slowly goes down if i leave it testing is that normal and  i have nothing coming out the sparkplug
  • Hisun .500 changed the title to 2008 hisun 500 utv no spark
To start with the voltage to the coil is a capacitive discharge voltage not a dc voltage. The basics is the CDI (capacitive discharge unit) operates off the magneto generated voltage and a pickup that tells it when to fire. The capacitor discharge unit charges up while the magneto turns past the charge coil and then fires the coil when a magnet passes the pickup coil. If you are not electrically oriented, you will have trouble repairing this.
Here is a repair manual in case you don't have one. Follow the troubleshooting procedures in the manual. After you familiarize yourself with the manual if you need help I will help you.
hs500utv.pdf
    • By Tarak1980
    • By BMurph
    • By BMurph
