ok so i have replaced everything ive got just about 9 or so volts to the wire at the  coil then it slowly goes down if i leave it testing is that normal and  i have nothing coming out the sparkplug
  • Hisun .500 changed the title to 2008 hisun 500 utv no spark
To start with the voltage to the coil is a capacitive discharge voltage not a dc voltage. The basics is the CDI (capacitive discharge unit) operates off the magneto generated voltage and a pickup that tells it when to fire. The capacitor discharge unit charges up while the magneto turns past the charge coil and then fires the coil when a magnet passes the pickup coil. If you are not electrically oriented, you will have trouble repairing this.
Here is a repair manual in case you don't have one. Follow the troubleshooting procedures in the manual. After you familiarize yourself with the manual if you need help I will help you.
hs500utv.pdf
    • By Matthew Smith
      2013 Bennche Bighorn 700 EFI
    • By rdborra
    • By CYJSP2009
      Dear Friends,
      Buy 1 piece: Get 5% discount,
      Good Luck
      Casey / Leaf Asia
      July-07-2022
      Coleman UT 400 has a strong sulfur/emissions smell from exhaust all the time.  Kind of like it’s running rich and a catalytic converter is trying to make it run cleaner so it smells bad. Also misfires when warm. Idles fine. Full throttle fine. In between it cuts out. Do these have catalytic converters?  Almost acts like it might be clogged if so.
