I don't think that is a valid error code. You can look on this website to verify HUD ECU Hacker (netcult.ch) I have this software along with the real Tetris adaptor and I can connect to the dephi ECU, read and reset error codes. I tried the cheap route as far as adaptors go but ended up buying the real thing. Here's the link to the delphi ECU manualMicrosoft Word - Delphi_CTC_Small_Engine_EMS_Service_Manual_Rev1_Eng.doc (netcult.ch) At the end of the manual are all the error codes and there isn't a 1111 listed.
    • By KnS
      Hey Team, our issue is not as bad as some I've read here...  We put some songs one a 64GB USB stick, plugged it in and the USB icon is still greyed out and won't let you select.  Any suggestions?  All the songs are in the root directory.  Thanks, Kevin & Shelbie
    • By klm
    • By Some random dude
      2015 Hisun 700 Utv
