I was backing up a hill tonight with the diff lock on in my 08 prowler xtx and POP. i knew it didnt sound good so i drove up to the house and grabbed the front drivers side axle and sure enough the wheel end is flopping around inside the boot. I just got this prowler and was wondering if maybe it is possible for something to just pop out, or did i infact snap the shaft??? if i did wreck the cv does anyone know if the drivers side is considered the front "left" or "right"??? is there any cross reference parts that are cheaper that will fit??? any info would be great. thanks
Driver's side is front left.
    • By mcraigchr
      Howdy y'all,
      Craig C.
    • By camojay
    • By Robbie Wyre
    • By GaryC
    • By Gerals
