I was backing up a hill tonight with the diff lock on in my 08 prowler xtx and POP. i knew it didnt sound good so i drove up to the house and grabbed the front drivers side axle and sure enough the wheel end is flopping around inside the boot. I just got this prowler and was wondering if maybe it is possible for something to just pop out, or did i infact snap the shaft??? if i did wreck the cv does anyone know if the drivers side is considered the front "left" or "right"??? is there any cross reference parts that are cheaper that will fit??? any info would be great. thanks
Driver's side is front left.
    • By KimAC
      -Kim
    • By shawn b
    • By tskm
      Tom
    • By TPlummer
      Any ideas on using sound deafening mats? Have they helped with the noise? Worth it? These side by sides are so loud!
    • By Travis M
      Just purchased a T-Boss 760 and before putting any miles on it I'm going over all the fluids, grease and problem areas that I've read about online because I know the factory quality control is garbage.
      I've seen where everyone seems to have leaking axle seals after 2-300 miles on the T-Boss 550 and 760. I think I'm going to switch from the bellow-style diff breather to the automotive style diff breather that they use on my Tacoma and various other vehicles. I'll still keep it extended and infact run it even higher, probably into the air intake box, but I'm hoping this is what's causing the axle seal leak issue on these vehicles.
      I'll do the modification and report back every couple hundred miles and let you know. I currently only have 8 miles, so it will be a few months before I find out if mine leaks like everyone elses.
