2020 Polaris Rzr XP Turbo Stealth Black
925cc turbo charged engine
168hp
64” wide
2,319 miles
161 hours
Complete oil change done recently and religiously using Mobil Oil products
Everything works as it should
Aftermarket accessories:
AMS black wheels with skat trak hub covers and black raceline lug nuts
14”x8” front wheels
14”x10” rear wheels
System 3 SS360 front sand tires
Pro Armor 16 paddle rear sand paddles
Rockford Fosgate 1,000 watt stage 5 stereo
Aftermarket Assassins Tunes 1-3 plus kid mode
Aftermarket Assassins Launch control (2 step)
Aftermarket Assassins 2500 rpm stall spring
Aftermarket Assassins S3 clutch kit
Aftermarket Assassins Blow Off Valve with filter
Trinity Stage 5 Cerakote slip on exhaust
NGK CR9EIX spark plugs
RPM Powersports silicone Intake and Charge tubes
Black aluminum roof
32” curved Rough Country single row light bar
Black aluminum lower doors
15” Rough Country rear view mirror
K&N air filter with outerwear
2 Tusk flag mounts (1 is damaged)
Chupacabra Offroad upper door bags
Polaris Click 6 retractable harnesses
.50 Caliber Racing middle bump seat
Super UTV tinted half windshield (have a brand new one to go with)
All stock parts are available to be put back on if wanted
$19,750
Located in Hugoton,Ks
Call/text 6204531197 for more info
      I've been having misfire issues with my UTV 400 when it gets warm and I've thrown all kinds of parts at it so far with no permanent resolution.  Today I removed the O2 sensor and it is black on the end.  To me that means it's running rich and/or the sensor isn't working.  I replaced the sensor with a new one and will see how it goes I guess.  With EFI, I'm wondering why the sensor would be this way with low hours and mileage?  Is there a way to adjust or lean out fueling on these?  Thanks in advance.
    • By Gorj
    • By aefron88
    • By SSgt1994
      Myron
